cwoodfield
Nov 29, 2025Aspirant
GS110EMX not tagging frames
I've had this switch for quite a while but haven't had a need to configure VLANs until now. I've started by moving all the ports to Vlan 2, and configuring ports 7 and 8 - part of an LACP bundle - as...
cwoodfield
Dec 02, 2025Aspirant
To follow up - I confirmed via a colleague running the same model of upstream router (a Mikrotik RB5009) that incoming tagged frames do appear in packet captures with their VLAN tags intact, which brings me back to the assertion that the switch is not tagging frames as it is configured to do.
As mentioned above, the "gold-standard" confirmation, which would be to examine the traffic via a mirror port, cannot be done since the switch doesn't appear to allow a member of an LACP bundle to be used as a mirror port source. Is this a known caveat or is there a workaround?
