cndesu
Jan 15, 2023Aspirant
GS110TP gets inactive on network
I have main router which was given by my ISP provider. I have two GS110TP switches connected to the router LAN socket ( I have only one LAN socket on main router). These two switches getting inactive...
michaelkenward
Jan 16, 2023Guru - Experienced User
What is that modem? What is your router?
A router with only one socket is rare. Sounds more like a modem. You can't use a bunch of swtches as a router.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Smart / Plus / Click Switches - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
cndesu
Jan 16, 2023Aspirant
Hi, Thanks for your reply.
Here are my answers to some of your questions.
What is that modem? What is your router? Eero 6+. This device was given by ISP. There are two ports at the back. He configured one as WAN and one as LAN. This device is among the recent varieties where the device can be programmed as a switch or a router. ISP programmed as router.
I could not find the same info from the netgear website. Is Eero doing that, to make them offline or netgear going to sleep mode. I have no idea.
Thanks for the help.
- michaelkenwardJan 16, 2023Guru - Experienced User
And the modem is?
The Eero 6+. is one of those odd "designed for WiFi" beasts. They don't feature here that often.
Did you look for the manuals for your switches?
See link above.
- schumakuJan 16, 2023Guru - Experienced UserSeveral reports random network switches going offline randomly in the Eero context. Could be caused by people operating more complex configurations like Mesh or WiFi Mesh.
Different methods like STP or proprietary loop prevention methods can trigger loop condition detections if there are multiple devices on the same L2 network.- cndesuFeb 02, 2023Aspirant
OK Thanks
