CraftyAndy's avatar
CraftyAndy
GS110TP IGMP querying
Hi there,
I was having some multicast issues and I thought perhaps it was due to not having an IGMP Querier on the network so I purchased the GS110TP to replace the switch I was using.
I believe I have it setup correctly, but I am not seeing any IGMPv2 queries or responses in Wireshark.
I have verified that the IGMP snooping is working correctly and devices show up in the IGMP snooping table.
I am on the latest firmware, and did a factory reset after doing the firmware update. An image is attached to show my configuration. I have not changed any settings in the VLAN tab.MySettings
  • Hi CraftyAndy
    Welcome to Netgear Community!
    Beside your current configuration, there something to be added.
    1.switching >muticast>igmp snooping>IGMP snooping vlan configuration.  Here add vlan 1 as igmp snooping vlan.
    2.switching >muticast>igmp snooping querier>Querier configuration.  Here enable Querier Admin Mode,add you can set IGMP Version,Query Interval as you want.
    After add  this you can check at switching >muticast>igmp snooping querier>Querier vlan status, it should show vlan 1 Operational State is Querier. Also ,at this time you can capture igmp query message via Wireshark.
    Regards
    Carl
    Netgear Employee
  • Carl_z's avatar
    Carl_z
    NETGEAR Expert
    Hi CraftyAndy
    Regards
    Carl
    Netgear Employee
    • CraftyAndy's avatar
      CraftyAndy
      Hi Carl,
      I had already done step 2 above (I realize now that my screenshot did not capture that..), but I had not done step 1. I had tried to but rather than clicking "add" I hit "apply" and nothing happened. When I re-did step 1 and hit "add" the entry was added and I now see the queries and the snooping table is being populated. Thank you!!
ProSupport for Business
