wuwu84
Jan 25, 2020Aspirant
GS110TP MIBs
Hi Netgear support,
can you please provide me a link to download the MIBs for GS110TP? I need it to switch ON/OFF poe admin mode via snmp.
Thank you very much!
wuwu84 wrote:
can you please provide me a link to download the MIBs for GS110TP? I need it to switch ON/OFF poe admin mode via snmp.https://netgear.com/support/ -> type your model, find your switch, head to downloads, and find https://www.netgear.com/support/product/GS110TP.aspx#download ... pick the MIB for the current firmware.
There isn another thread where a community member shows that the POWER-MIB are available on the GS110TP - "POWER-ETHERNET-MIB, part of the private MIB tree of Netgear, it doesn't implement the IETF OID" https://community.netgear.com/t5/Smart-Plus-Click-Switches/GS310TP-snmp-poe-disable/m-p/1796579/highlight/true#M13644
- DaneANETGEAR Employee Retired
You may download the GS110TP MIB on this link. The link will expire within 2-3 days.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team - schumakuGuru - Experienced User
There isn another thread where a community member shows that the POWER-MIB are available on the GS110TP - "POWER-ETHERNET-MIB, part of the private MIB tree of Netgear, it doesn't implement the IETF OID" https://community.netgear.com/t5/Smart-Plus-Click-Switches/GS310TP-snmp-poe-disable/m-p/1796579/highlight/true#M13644- wuwu84Aspirant
Hi schumaku,
thanks for that.
It works great with .1.3.6.1.4.1.4526.11.16.1.1.1.3.1
:smileyvery-happy:
