slamdunkthefunk's avatar
Mar 31, 2020
GS110TPP - can I aggregate uplink ports?
Hi there.    I'm interested in the GS110TPP Smart Managed Pro Switch.   I'm trying to determine if it is possible to aggregate (using LACP) the two 1 Gigabit dedicated copper uplink ports to a LA...
  • JohnC_V's avatar
    Apr 01, 2020
    slamdunkthefunk,
    Welcome to our community! :)
    It should work fine as long as the configuration matches your router. It does support LAG too. May I know if you really need a POE switch for your network?
    John
    NETGEAR Community Team
ProSupport for Business
