slamdunkthefunk
Mar 31, 2020Aspirant
GS110TPP - can I aggregate uplink ports?
Hi there. I'm interested in the GS110TPP Smart Managed Pro Switch. I'm trying to determine if it is possible to aggregate (using LACP) the two 1 Gigabit dedicated copper uplink ports to a LA...
- Apr 01, 2020
Welcome to our community! :)
It should work fine as long as the configuration matches your router. It does support LAG too. May I know if you really need a POE switch for your network?
John
NETGEAR Community Team
JohnC_V
Apr 01, 2020NETGEAR Employee Retired
John
slamdunkthefunk
Apr 01, 2020Aspirant
Thanks for the confirmation.
Yes I require PoE, as I have multiple PoE wireless access points that will be be connected to the switch, as well as a PoE IP camera.
