harry7922
Oct 28, 2020Guide
GS110TPv3 incompatible with Ubiquiti Unifi UAP-AC-M
Hi everyone, I'm faced with an issue between the devices GS110TPv3 and Unifi UAP-AC-M. On the UAP-AC-M I have two SSIDs: MAIN -> This SSID is using untagged network communication SECOND -> This...
- Oct 30, 2020
Hallo Harry,
The AP works correct on the GS750E and on the same port in use as a trunk to the GS110TPv3 when I get you right.
Looked twice over the screenshots today - can't spot anything obviously on either device. Hmmmm.....see what you feel.
Just wild ideas, current GS110TPv3 firmware, factory reset, reconfig from scratch, ... Clueless.
-Kurt
schumaku
Oct 28, 2020Guru - Experienced User
Show the VLAN and VLAN port config for both switches, for both the trunk connection and the trunk-like connection to the APs. There must be something wrong on that level.
harry7922
Oct 29, 2020Guide
schumaku :
Attached the screenshot from Switches with hints on which port the devices are connected . I checked it a hundred times, but maybe I misunderstood something.
Thanks for your help!
VLAN-GS110TPVLAN-GS750E
- schumakuOct 29, 2020Guru - Experienced User
Will follow-up as soon as a moderator has accepted the in-line images.
- harry7922Oct 30, 2020Guide
- schumakuOct 30, 2020Guru - Experienced User
Hallo Harry,
-Kurt
