harry7922
Oct 28, 2020Guide
GS110TPv3 incompatible with Ubiquiti Unifi UAP-AC-M
Hi everyone, I'm faced with an issue between the devices GS110TPv3 and Unifi UAP-AC-M. On the UAP-AC-M I have two SSIDs: MAIN -> This SSID is using untagged network communication SECOND -> This...
- Oct 30, 2020
Hallo Harry,
The AP works correct on the GS750E and on the same port in use as a trunk to the GS110TPv3 when I get you right.
Looked twice over the screenshots today - can't spot anything obviously on either device. Hmmmm.....see what you feel.
Just wild ideas, current GS110TPv3 firmware, factory reset, reconfig from scratch, ... Clueless.
-Kurt
harry7922
Oct 29, 2020Guide
schumaku :
Attached the screenshot from Switches with hints on which port the devices are connected . I checked it a hundred times, but maybe I misunderstood something.
Thanks for your help!
VLAN-GS110TPVLAN-GS750E
schumaku
Oct 29, 2020Guru - Experienced User
Will follow-up as soon as a moderator has accepted the in-line images.
- harry7922Oct 30, 2020Guide
- schumakuOct 30, 2020Guru - Experienced User
Hallo Harry,
-Kurt
Dear Kurt,
thanks for your answer.
On one hand I'm glad that it seems to be not my fault. On the other hand, I don't know how to solve the issue without netgear support.
I also tried other ports with the UAC-AP-M on GS110TP but same result. The untagged packets are not "forwarded" to the trunk port.
Yes, it's the current firmware. But it was same issue with old ones. I will reset the device tomorrow and try it again.
When this will be without success, do you know how I can proceed?
On GS750E I had an issue between the switch an the guest-port with FritzBox. Therefore the support found an issue in firmware (but this was within the 90days "professional support". Now next issue on next switch. It is getting annoying :-(
Thanks again!
Best,
Harry
