harry7922
Oct 28, 2020Guide
GS110TPv3 incompatible with Ubiquiti Unifi UAP-AC-M
Hi everyone, I'm faced with an issue between the devices GS110TPv3 and Unifi UAP-AC-M. On the UAP-AC-M I have two SSIDs: MAIN -> This SSID is using untagged network communication SECOND -> This...
- Oct 30, 2020
Hallo Harry,
The AP works correct on the GS750E and on the same port in use as a trunk to the GS110TPv3 when I get you right.
Looked twice over the screenshots today - can't spot anything obviously on either device. Hmmmm.....see what you feel.
Just wild ideas, current GS110TPv3 firmware, factory reset, reconfig from scratch, ... Clueless.
-Kurt
harry7922
Oct 30, 2020Guide
schumaku
Oct 30, 2020Guru - Experienced User
Hallo Harry,
-Kurt
- harry7922Oct 30, 2020Guide
Dear Kurt,
thanks for your answer.
On one hand I'm glad that it seems to be not my fault. On the other hand, I don't know how to solve the issue without netgear support.
I also tried other ports with the UAC-AP-M on GS110TP but same result. The untagged packets are not "forwarded" to the trunk port.
Yes, it's the current firmware. But it was same issue with old ones. I will reset the device tomorrow and try it again.
When this will be without success, do you know how I can proceed?
On GS750E I had an issue between the switch an the guest-port with FritzBox. Therefore the support found an issue in firmware (but this was within the 90days "professional support". Now next issue on next switch. It is getting annoying :-(
Thanks again!
Best,
Harry
- harry7922Oct 31, 2020Guide
schumaku : THANKS for your help.
I made a factory reset and configured the switch like it was before - and now it works!
Really strange.
Thanks again and best regards,
Harry
- schumakuOct 31, 2020Guru - Experienced User
Harry,
Reset which of the two switches?
Have plugged a GS750E between a PoE switch and an AP - SSIDs mapped to VLANs (tagged on the wire) don't get any IP assigned.
-Kurt
- harry7922Nov 01, 2020Guide
Hi Kurt,
had to reset and reconfigure the GS110TP.
Because this switch was internally not forwarding the request coming from AP to other ports (also not to trunk port to other switch(es)).
Best,
Harry
