harry7922
Oct 28, 2020Guide
GS110TPv3 incompatible with Ubiquiti Unifi UAP-AC-M
Hi everyone, I'm faced with an issue between the devices GS110TPv3 and Unifi UAP-AC-M. On the UAP-AC-M I have two SSIDs: MAIN -> This SSID is using untagged network communication SECOND -> This...
- Oct 30, 2020
Hallo Harry,
The AP works correct on the GS750E and on the same port in use as a trunk to the GS110TPv3 when I get you right.
Looked twice over the screenshots today - can't spot anything obviously on either device. Hmmmm.....see what you feel.
Just wild ideas, current GS110TPv3 firmware, factory reset, reconfig from scratch, ... Clueless.
-Kurt
harry7922
Nov 03, 2020Guide
I was analyzing the issue again. And hopefully I found the reason why.
When I activate the LAG in GS1110TP, the VLAN-configuration for the involved Trunk-Ports is not cleared for "the single Ports".
This means, that in my example the Port g1 and g2 had - also after putting these prots to LAG - VLAN1 as untagged. Also the LAG of these Ports had VLAN1 as untagged.
I removed any VLAN relationship to the "single Ports" because they are getting it from the related LAG!
My other switch from netgear is removing this by default when activating an LAG.
After that I made a reboot and cleared the address table.
Now it works - hopefully without further issues.
I hope this will help also anyone else.
BR, Harry
schumaku
Nov 03, 2020Guru - Experienced User
Hallo Harry,
harry7922 wrote:When I activate the LAG in GS1110TP, the VLAN-configuration for the involved Trunk-Ports is not cleared for "the single Ports".
This means, that in my example the Port g1 and g2 had - also after putting these prots to LAG - VLAN1 as untagged. Also the LAG of these Ports had VLAN1 as untagged. I removed any VLAN relationship to the "single Ports" because they are getting it from the related LAG!
This is correct - the LAG-port VLAN membership must be set to [ ] unassigned on the Smrt Managed Pro switches.
harry7922 wrote:My other switch from netgear is removing this by default when activating an LAG.
Newer Smart Managed Plus switches indeed adjust the LAG VLAN-per-port membership autoatically - at least while the LAG is up.
Grüsse
-Kurt
