spuch
Nov 30, 2020Guide
GS116Ev2 / GS108Ev3 losing management IP if dhcp server is not reachable after 2 hour renewal period
There seems to be a bug within the dhcp client of GS116Ev2 (Firmware Version 2.6.0.43) and GS108Ev3 (Firmware Version 2.06.14). If the switch is configured to get its management IP address from a lo...
De_nn_is
May 07, 2021Aspirant
Hello all together,
does the problem still exist? It looks like my new GS308E has the same behavior. In this case the swicht is not usable for me, because behind the swicht is an important part of my smart home. And when this siutaion happens, my smart home works not correct anymore. An at the moment it looks like i have the same problem.
Kind reagards
Dennis
- schumakuMay 07, 2021Guru - Experienced User
De_nn_is wrote:does the problem still exist? It looks like my new GS308E has the same behavior.
What problem, what behavior?
This thread does talk about the way the DHCP client (for the local switch management) and the minimum MTU required to access the management Web UI. Undoubted, the DHCP implementation is still the same; no idea if the minimum MTU enforcement prohibiting the switch Web UI access on smaller MTU conditions (like through a VPN) is in place on your switch model and the undefined firmware version.
De_nn_is wrote:In this case the swicht is not usable for me, because behind the swicht is an important part of my smart home. And when this siutaion happens, my smart home works not correct anymore. An at the moment it looks like i have the same problem.
There is no problem in this thread that is happen suddenly and making the switch no longer workable in general.
- De_nn_isMay 07, 2021Aspirant
The behavior of th DHCP. My Problem is, that when the DHCP-Server is not reachable, the GS308E lost the static IP. Thus, the switch and all devices behind the switch are no longer accessible. That is a big Problem in my private network. Most of the time this happens when I am not at home and therefore I can't pull a plug. During this time, my smart home does not run correctly.
Or am I misunderstanding this thread?
Greetings
DennisPS: My swicht is the GS308E with the actuall version V1.00.08GR.
De_nn_is wrote:The behavior of th DHCP. My Problem is, that when the DHCP-Server is not reachable, the GS308E lost the static IP. Thus, the switch and all devices behind the switch are no longer accessible.
Or am I misunderstanding this thread?Yes, I think you do. This does only affect the management of the switch. The other L2 traffic, including any communication to your IoT isn't affected by this issue at all-
