spuch
Nov 30, 2020Guide
GS116Ev2 / GS108Ev3 losing management IP if dhcp server is not reachable after 2 hour renewal period
There seems to be a bug within the dhcp client of GS116Ev2 (Firmware Version 2.6.0.43) and GS108Ev3 (Firmware Version 2.06.14). If the switch is configured to get its management IP address from a lo...
De_nn_is
May 07, 2021Aspirant
schumaku wrote:
De_nn_is wrote:does the problem still exist? It looks like my new GS308E has the same behavior.
What problem, what behavior?
The behavior of th DHCP. My Problem is, that when the DHCP-Server is not reachable, the GS308E lost the static IP. Thus, the switch and all devices behind the switch are no longer accessible. That is a big Problem in my private network. Most of the time this happens when I am not at home and therefore I can't pull a plug. During this time, my smart home does not run correctly.
Or am I misunderstanding this thread?
Greetings
Dennis
PS: My swicht is the GS308E with the actuall version V1.00.08GR.
schumaku
May 07, 2021Guru - Experienced User
De_nn_is wrote:The behavior of th DHCP. My Problem is, that when the DHCP-Server is not reachable, the GS308E lost the static IP. Thus, the switch and all devices behind the switch are no longer accessible.
Yes, I think you do. This does only affect the management of the switch. The other L2 traffic, including any communication to your IoT isn't affected by this issue at all-
