Adt57
Jun 13, 2023Aspirant
GS116Ev2 web gui no longer works with latest iOS 15
Access to the GUI works fine with Windows browsers, however, since iOS 15.7.6? I can login but only see details on the left/menu side, the right pane is always blank? This fails for iPad and iPhone, ...
schumaku
Jun 13, 2023Guru - Experienced User
Have no GS116Ev2 at hand, but a bunch of other Plus switches, all on the current/last released firmware, including the last Multi-Language 2.6.0.48, or Multi-Language 1.6.0.17, or the English 1.00.11 available on various Plus switches. Trouble-free Web UI access from an iPhone 14 Pro, operating on iOS 16.5, with the about current Safari, and/or Chrome and/or Google (sigh, the one not showing the @).
- Adt57Jun 13, 2023Aspirant
- schumakuJun 13, 2023Guru - Experienced User
ok, thank you for the update...
Thanks for trying that, this is really odd and frustrating…
… it’s running firmware 2.6.0.48, old but apparently the latest.
So, on a old phone 7, that’s stuck on 15.7.6 it works fine…
… but I’ve now tried it on an iPhone X and two iPad Pro 2020’s each running 16.5 (apologies it should not have said 15 in the header) and the right hand pane is blank for all options I chose on the pane on the left. These are all using the same network…
I’ve now tried browsers - Edge, Chrome, Photon, Ecosia and Firefox - all with nothing on in the right hand pane.
Windows works fine…
Sorry, my replies ended up as new posts…
