Adt57
Jun 13, 2023Aspirant
GS116Ev2 web gui no longer works with latest iOS 15
Access to the GUI works fine with Windows browsers, however, since iOS 15.7.6? I can login but only see details on the left/menu side, the right pane is always blank? This fails for iPad and iPhone, ...
Adt57
Thanks for trying that, this is really odd and frustrating…
… it’s running firmware 2.6.0.48, old but apparently the latest.
So, on a old phone 7, that’s stuck on 15.7.6 it works fine…
… but I’ve now tried it on an iPhone X and two iPad Pro 2020’s each running 16.5 (apologies it should not have said 15 in the header) and the right hand pane is blank for all options I chose on the pane on the left. These are all using the same network…
I’ve now tried browsers - Edge, Chrome, Photon, Ecosia and Firefox - all with nothing on in the right hand pane.
Windows works fine…
schumaku
Jun 13, 2023Guru - Experienced User
- schumakuJun 13, 2023Guru - Experienced User
- DavidGoJun 15, 2023NETGEAR Expert
My recommendation would be to log a support ticket. We can troubleshoot and if necessary, raise a bug to engineering team (sounds like it may be likely outcome).
I also don't have GS116Ev2 to test right now to confirm.
Thanks
DavidGo
- Adt57Jun 15, 2023Aspirant
Thanks DavidGo
… don’t think I can raise a support ticket as I’m a home user with no support contract.
It sounds like Netgear use some ‘old’ web page technology’ that Apple have updated within their API’s, thus it affects all the Browsers I mentioned. I use the switch port monitoring and statistics so had to borrow my brother’s iPhone 7, on iOS 15.7.6 as it doesn’t support 16. Also found my Android based TV works…
While this is obviously an Apple iOS change, somehow I doubt they will respond to a please fix this?
Would I need to buy a Netgear support contract to progress this?
