Adt57
Jun 13, 2023Aspirant
GS116Ev2 web gui no longer works with latest iOS 15
Access to the GUI works fine with Windows browsers, however, since iOS 15.7.6? I can login but only see details on the left/menu side, the right pane is always blank? This fails for iPad and iPhone, ...
Adt57
Jul 04, 2023Aspirant
This case has been now been raised by 3rd Level Support to the Engineering Team so, hopefully, it’s been reproduced and on it’s way to be fixed…
… seems a real odd one to be specific perhaps to this mode?
I’ve tried many different browsers on original iPad Pros and 5th gens, as well as my iPhone X and all have this issue. An old iPhone 7 restricted to 15.7.7 works fine with the identical networks - house intranet and mobile 4G GPRS.
The latest software is 2.6.0.48 and released 2 Dec 2020, so a bit concerned… ?
- Adt57Aug 04, 2023Aspirant
Well I finally got a reply saying web access via iOS iPad and iPhone is not supported…
… as this worked fine for over two years until Apple changed something, this suggests Netgear is just unwilling to try and work with iOS API changes, this is unacceptable for a product with lifetime support.
It still works fine on an old iPhone 7 that only gets security updates on iOS 15.7…
There’s been no updates for this switch for well over a year, seems very unprofessional to me…
Case #: 47386813
Case Summary: GS116Ev2 - Alan Taylor - GUI doesn't works with iOS 16
Product: ProSAFE Plus 16 ports gigabits switch(GS116Ev2)Received feedback from the engineering team:
- local web browser management of the GS116Ev2 by iOS devices(iphones and ipads) is unfortunately not supported.
- because of this it won't be unfortunately possible to resolve the reported issue.Best Regards,
Netgear L3 Support
