schunckt
Jun 01, 2021Aspirant
GS116ev2 Web Interface dead after firmware update, any way to recover?
As the topic says, the box is dead.
I've alrady successfully updated 4 other ones but this latest one now doesnt work any longer.
traffic works, ping response is there. Also I did a factory reset which went back from static do DHCP with new IP.
Ping still works but the web interface is dead.
Side note - but need to confirm later the day (trying reset / power cycle)
It looks like all other 4 which did work previously are also DEAD !!!!!!!!
WTF ....????
Old firmware was 2.6.0.24 updated to 2.6.0.48 (the previous 4 on 28-Feb and they did work since then)
How to recover without replacement??? Any clue, anyone..????
T.
- schuncktAspirant
Don't know if and how to modify my own message that's why here is an update.
It seems the switch web page really IS working!
After connecting the laptop wired to the switch(es) not using WLAN (Fritzbox) it works!
Then I've again access to all switches web pages!
When going back to WLAN it fails.
Also fails from my current remote site (VPN, different from the WLAN router above) so it's unlikely the Laptop...
Is there any intentional access restriction (security-wise) but how? This also would not explain why i can access ALL switches if wired.
I think i need some Wireshark session next weekend.
T.
Suspect multiple "features" are coming together with this firmware:
- VPN: fixed MTU, does not allow MTU smaller than 1500
- Potential "security" changes causing a problem with the ARP resolution (e.g. as used by Proxy ARP on "modern" access points)
