GRSmith00
Aug 03, 2020Follower
GS305E - Communicating between subnets
I was looking to buy the GS305E switch and was wondering if it would work for my needs.
How I would have the switch set up is my router from my ISP (either in router or modem mode) would plug into one of the ports, and then connected to the GS305E would be all our other wired connections and switches as well as our mesh wifi system.
With how our mesh wifi system works, it on it's own subnet (for example, at the moment with our ISPs router, all the wired traffic is on 192.168.0.x/24 with the IP of the wifi system being 192.168.0.10, and the wireless traffic being 192.168.1.x/24 with the gateway to the wifi routers being 192.168.1.1).
Because of how our ISPs router works, the wired and wireless connections can't communicate with eachother as it doesn't support communication between subnets.
Would the GS305E allow me to communcate between the subnet with all the wireless connections and the subnet with all the wired connections, such that, for example, my wired in PC can commincated with my wireless printer, or my phone could chromecast to our wired in TV?
If not, which Netgear devices would allow me to do that?
Afraid, no Smart Managed Plus switch does support inter-VLAN routing.
The problem for your (and many other users looking into similar solutions) use case is that there is more required than pure routing - that's what some L2+/L3 switches or routers/SOHO/SMB security appliances would support (but e.g. not your ISP router) - the problem is that printers, media players, ... and the like use standard discovery protocols, for example Bonjour/mDNS or UPnP SSDP, other IoT or network devices use proprietary stuff often based on IP Broadcast. And these are designed to work on a single broadcast domain only - a single flat LAN/VLAN and IP subnet.
Adding a classic router or security appliance does still require a static route from the default gateway (that's the ISP router) on the LAN interface to another subnet pointing to the router interface on that same LAN subnet. Otherwise you would have to deploy static routes on all systems on the primary LAN - what is in between unhandy to impossible.
All these are often the killer for well intended security design...
1 Reply
