C2L_Eu
Jul 20, 2020Aspirant
GS305E - VLAN Config
Hi All, Hopefully this is an easy question to answer but have strggled for the last few days, trying every combination to get VLANs to work. VLAN 10 - Management VLAN 30 - Guest VLAN 40 - S...
- Jul 20, 2020
C2L_Eu wrote:VLAN 10 - Management
Eth1-4 = These should be VLAN 40 tagged. They connect to devices like TV's or AMPS
Eth 5 = Truck to the rest of the network which has VLAN tagging working fine with WAC505's.
No, ports where you connect devices like TV, AMP, computers, IoT must be always untagged.
The screenshots provided look correct, #1-4 VLAN ID 40 Untagged, PVID 40. #5 VLAN ID 40 Tagged. Double check the peer switch on the trunk is configued similar.
