uhwd
May 01, 2023Aspirant
GS305E/GS308E HTTP connction lost in Loader Mode
All my GS305E and GS308E Plus switches are loosing HTTP connection while acitivating Loader Mode for updating firmware. Access is via 802.1Q VLAN1 and Webbrower rsp. ProSAFE Plus utility. VLAN1 is al...
uhwd
May 02, 2023Aspirant
Yes, the normal Web-UI is coming back.
schumaku wrote:... the very basic IP stack can't deal with tagged frames.
That's the point, finding a network driver that is passing VLAN tags would solve the problem. Thank you.
schumaku
May 02, 2023Guru - Experienced User
No, use untagged frames only. Connect the GS305E/GS308E and all other Plus switches (except the few versions built on fully managed cores) to a switch port not configured for tagged frames.
