ds563289290hg
Apr 08, 2024Aspirant
GS305EPP Port 4 Not Forwarding DHCP
My GS305EPP is not forwarding DHCP on Port from Firewalla Gold. Port 3 is configured in PVID exactly the same and the QNAP DHCP gets an address properly (switched QNAP to Port 4 and it didn't conne...
schumaku
Apr 08, 2024Guru - Experienced User
Scratch configured or restored some old backup config?
Can't tell you what the odd solid amber PoE LED want to indicate there - something must go badly wrong. Please open ticket with the Netgear Support please, add a link to this thread.
- ds563289290hgApr 08, 2024AspirantI did open a ticket. The user manual states solid amber indicates a POE error. In the POE page I reset Port 4 but it stayed amber. That port was working on and off before the amber color came on. Will post link when I hear back. đ
- ds563289290hgApr 08, 2024AspirantI set it up as new as I had installed the latest firmware on it and my saved configuration was on older firmware.
