ds563289290hg
Apr 08, 2024Aspirant
GS305EPP Port 4 Not Forwarding DHCP
My GS305EPP is not forwarding DHCP on Port from Firewalla Gold. Port 3 is configured in PVID exactly the same and the QNAP DHCP gets an address properly (switched QNAP to Port 4 and it didn't conne...
schumaku
Apr 08, 2024Guru - Experienced User
So this issue - both the PoE error LED, and partial loss of communication (DHCP) - does only occur with the port connected to this Firewalla Gold, but not while connected to another network also serving DHCP?
schumaku
Apr 09, 2024Guru - Experienced User
Assuming your Firewalla Gold isn't a PoE PD, and it does not request PoE, keep the PoE enabled (default, don't disable). Is the suspect false PoE-error indication retained?
- ds563289290hgApr 09, 2024Aspirant
The Netgear GS305EPP is connected to the Firewalla Gold Router via the UPLINK port which is not POE.
I enabled POE on Port 4. Right Light still AMBER.
- schumakuApr 09, 2024Guru - Experienced User
Unplugged and replugged the link?
