ds563289290hg
Apr 08, 2024Aspirant
GS305EPP Port 4 Not Forwarding DHCP
My GS305EPP is not forwarding DHCP on Port from Firewalla Gold. Port 3 is configured in PVID exactly the same and the QNAP DHCP gets an address properly (switched QNAP to Port 4 and it didn't conne...
schumaku
Apr 09, 2024Guru - Experienced User
Assuming your Firewalla Gold isn't a PoE PD, and it does not request PoE, keep the PoE enabled (default, don't disable). Is the suspect false PoE-error indication retained?
ds563289290hg
Apr 09, 2024Aspirant
The Netgear GS305EPP is connected to the Firewalla Gold Router via the UPLINK port which is not POE.
- ds563289290hgApr 09, 2024Aspirant
I enabled POE on Port 4. Right Light still AMBER.
- schumakuApr 09, 2024Guru - Experienced User
Unplugged and replugged the link?
Yes, still Amber. The Left Light blinks Green as if passing traffic but MBP will not get DHCP IP Address just like TV and QNAP on Port 4.
