Swiftbrook
Nov 30, 2024Follower
GS305P no PoE
I have a GS305P and I’m trying to use it to connect / power 2 x Wireless Access Points. However it isn’t showing that it’s providing PoE on either of the WAP legs.
I have used a 6w independent power supply for each WAP leg to check that the WAPs work OK (and the do).
Any suggestions as to how I can get the switch to put PoE down these two legs?
Thanks.
1 Reply
What WIreless Access Points (make, model, firmware, ... ) are we facing here?
