NG7856
Nov 03, 2023Guide
GS305PV3 PoE and Optical Terminal Network ONT PoE
I have a question that might be crazy but my fiber optic to my house is not near any power supply so I do not know how to power the ONT without new wiring. I was wondering if I can use a Netgear PoE GS305PV3 to power the ONT. I found a ONT PoE.
Fiber --> ONT (PoE) -----> ROUTER ------> PoE Switch ---|
Somehow I do not think this will work but I had to ask.
1 Reply
The PoE switch port (the PSE) can't magically power the ONT PD "through" the router. No tricks, no double bottom.
