securutybyte
Aug 26, 2020Aspirant
GS308E & Unifi AP vLAN
Hi I have a Unifi AP and I am trying to assign vLANs to my wireless networks. I am using a Netgear GS308E smart managed switch and an Untangle router. The router is plugged into port 1 of the...
- Aug 26, 2020
Welcome to our community! :)
It seems that you are having issues with the VLAN configuration of your switch going to your AP. I saw that your VLAN 30 doesn't have any members. You must tag the port of the switch on port 8(AP) and also your uplink(port 1) for VLAN 30 and leave the PVID to 1.
Basically, if the device is VLAN aware, you always need to tag the port in order for the VLANs to pass through properly. We only use Untag for devices that don't support any VLANs.
I hope this helps :)
John
NETGEAR Community Team
schumaku
Aug 26, 2020Guru - Experienced User
Key problem here isn't the Netgear switch - obvious one does run each VLAN (probably expect the base VLAN 1) so VLAN 20 (surveillance), and much more VLAN 30 from the router to the UI AP is run tagged, and the router doing DHCP, routing, NATing, for the x.x.30.x IP subnet - very similar to your surveillance VLAN 20.
The point with Unifi is _always_ that users don't see what is technically configured under the hood when setting up e.g. a "network", an "SSID". So much more problem understanding Unifi's control. Interestingly, these questions always hit the Netgear community.
