securutybyte
Aug 26, 2020Aspirant
GS308E & Unifi AP vLAN
Hi I have a Unifi AP and I am trying to assign vLANs to my wireless networks. I am using a Netgear GS308E smart managed switch and an Untangle router. The router is plugged into port 1 of the...
- Aug 26, 2020
Welcome to our community! :)
It seems that you are having issues with the VLAN configuration of your switch going to your AP. I saw that your VLAN 30 doesn't have any members. You must tag the port of the switch on port 8(AP) and also your uplink(port 1) for VLAN 30 and leave the PVID to 1.
Basically, if the device is VLAN aware, you always need to tag the port in order for the VLANs to pass through properly. We only use Untag for devices that don't support any VLANs.
I hope this helps :)
John
NETGEAR Community Team
JohnC_V
Aug 26, 2020NETGEAR Employee Retired
John
securutybyte
Aug 27, 2020Aspirant
Hi John
Thank you! That fixed it :)
I'd removed all the vLAN30 members after my last failed attempt. Where I had been going wrong is that I had been changing the PVID too.
Cheers
Mike
