sascha_52
Apr 03, 2022Aspirant
GS308E Access Management Site
Hello, I currently used two GS305e at different locations at home. Between the switches I used a trunc-connection with VLAN 101 (192.168.2.0/24) and VLAN 200 (192.168.10.0/24) on Port 5. Port 5 i...
sascha_52
May 05, 2022Aspirant
Hello,
short update:
My case in processing since 4 weeks. A lot of posts later the supporter has not yet managed to configure the switches as I specified to reproduce the problem. 🙄
I do not give up 🙂
Sascha
sascha_52
Jul 08, 2022Aspirant
Final State:
from Support ...
"We have received an update from the Engineering team, who could reproduce the issue and find the root cause.
The root cause is GS308E chip can't reply to ARP with the tag however, GS305E can send the reply to ARP with the tag."
"It is a Hardware limitation. It cannot be fixed by software updates." ☹️
Workarround should be use PVID (@GS305E) to retagging packets from GS308E, but it's no solution for direct connections from other hardware with 802.1Q.
Ticket is closed.
- waxarJul 08, 2022Tutor
That is beyond ridiculous... So they're saying that the chip supports tagging all other traffic, but is unable to tag its own? And what about the second issue when the replies are broadcast on all ports? Is it another "hardware limitation"? I think I'm done with Netgear...
- schumakuJul 08, 2022Guru - Experienced User
Reality is: These are making use of configurable switch chips.
waxar wrote: I think I'm done with Netgear...These re indeed chipset limitations, several vendors offer the almost exact same devices and the similar variance, some direct chipset related, some related to the earlier mentioned microcontroller implementation.
If you expect strict managed VLAN, buy switches supporting this.
