RAEC617
Nov 10, 2022Aspirant
GS308E smart managed plus switch
Thank you for the reply, no firmware update. I did check the manual and it said got to 192.168.0.239 I did but my system keeps timing out, now I did get on when I first this to set up a login and password. But now my system keep telling me times out , I restarted and I reset the switch. I just want to get to the page with the switch is but can't seem to get there. I did no changing to the PC or the network I have I have it into a eero Pro6 for the extra ports b/c the pro6 only has 2 ports and I prefer wired over wireless.
Thank you
1 Reply
Permitting the GS308E is connected at boot- power-up time to one of these eero LAN ports (start with the unit doing the NAT router - so the one connected with the other Ethernet port to the cable modem) - it will get an IP address assigned by the eero router. At that point, you can use either the NETGEAR Switch Discovery Tool on a PC/Mac/Linux system or simply use the Netgear Insight App to discover the network and hopefully able to locate the GS308E with it's assigned IP address.
This is by far not the only thing the NETGEAR 5-Port and 8-Port Gigabit Ethernet Smart Managed Plus SOHO Switch Model GS305E and GS308E Installation Guide tells the interested reader.
Whatever happened since - disconnected from the network, so no connection to the router (DHCP server) for example, restarted without the . The switch will continue to get it' IP address from the router DHCP server. If it does not have an option to reserve the MAC-IP address pair so always the same IP would be assigned, if it does not have some local name-to-DNS service allowing to use DNS based on the switch name, ... you need to continue using either the utility or the App to find the IP address assigned (or worst case to realize there was no network connection to the router at switch power-up time.
