RangaG
Nov 02, 2024Aspirant
GS308E Speed Issue
I have fiber from my ISP. The line coming into the house is connected to a orbi Wifi router. There is an ethernet port on the orbi router that I have plugged into my GS308E ( managed ) (into port an...
Nov 02, 2024Guru - Experienced User
Do the PCs show 1000 when connected directly to the back of the Orbi router?
Do other devices show 1000 when connected to this switch?
What is the brand and model# of the ethernet adapters installed in these two PCs?
Make sure all ethernet drivers for these adapters are up to date in this two PCs from the enterner adapter Mfr.
Check the advanced settings for the ethernet adapter driver to see if any advanced connection link speeds can be set. Most have this option.
What is the model # of the Orbi router?
- RangaGNov 09, 2024Aspirant
Yes when connected directly to the PC it shows 1000 , ALl cabled are connected and i see the networks is up and running .
