RangaG
Nov 02, 2024Aspirant
GS308E Speed Issue
I have fiber from my ISP. The line coming into the house is connected to a orbi Wifi router. There is an ethernet port on the orbi router that I have plugged into my GS308E ( managed ) (into port an...
schumaku
Nov 03, 2024Guru - Experienced User
RangaG wrote:
I have fiber from my ISP. The line coming into the house is connected to a orbi Wifi router. There is an ethernet port on the orbi router that I have plugged into my GS308E ( managed ) (into port and I can see that the speed coming into the switch is 1000M but the two connections I have out to other PCs in the house are only showing 100M (set to auto) and there is no option to select 1000M. what is the solution to fix the issue.
The IEEE standards require Ethernet link speed negotiation for Ethernet link speeds starting from 1000M, this is why there is no such control.
Such a control would won't magically fix anything on the issue - or more anwer your question. The majory of issues why a link is not operating at 1 GbE (or faster) is caused by bad, wrong wiring, cabling, or poor connectors. For these link speeds, four pairs are required. In case one of the four pairs isn't correctly working, only Fast Ethernet (100M) - requiring only two cable pairs - is workable.
Not a switch problem at the end of the day....
