novicenetwork
Apr 12, 2022Guide
GS308E Speed problem
I have google fiber for my ISP. The line coming into the house is connected to a Google Wifi point serving as a modem. There is an ethernet port on the Google Wifi that I have plugged into my GS308...
- Apr 13, 2022
Glad to see it was a cable issue.
You might mark it solved so others aren't still trying to fix it then 🙂
I haven't had a whole lot of issues with cat 6 cables but cat 5e its been hit or miss.
Apr 12, 2022Guru - Experienced User
do your computer support gigabit?
try using a good quality cat 6 cable. I've seen sketchy cat 5e default back to the 10/100mbps and not gigabit.
Not saying you do sketchy work but it only takes a poor crimp or strip to cause issues.
