thom9999
Feb 16, 2024Aspirant
GS308EP 1000M Not Available
Fired up with V1.0.1.1 firmware out of the box. Connected to Gigabit port on switch. 100M connection. Went to web interface and edited a different port not in use. Pulled down the Speed and ...
- Feb 16, 2024
Problem solved: Netgear Support said the 1000M pulldown is not an option.
Tried a different cable and it worked. 'Duh' on my part for thinking a 5E cable was in good working order.
thom9999
BrianL
Feb 16, 2024NETGEAR Moderator
Hi thom9999,
By default, the port speed on all ports is set automatically (Auto) after the switch determines the speed using auto-negotiation with the linked device. Also, the left port LED will indicate the following.
Solid green: 1000Mbps link on this port.
Blinking green: 1000Mbps activity on this port.
Kind regards,
