tmcarr1138's avatar
tmcarr1138
Initiate
Dec 01, 2022
GS308T Uses Internally Created SSL Certificates Instead of Certificates That I Upload
I have a GS308T on Boot Version 1.0.0.1 and Software Version 1.0.5.6.  After disabling HTTPS Admin Mode, I went to the Maintenance > Update > HTTP Firmware/File Update menu, I have uploaded my certif...
  • tmcarr1138's avatar
    Dec 01, 2022
    It appears that I have found the issue.  The "X.509 Public Certificate PEM" shouldn't be my certificate authority/intermediate authority but rather just the certificate created for the switch.  The "X.509 Certificate Private Key" shouldn't be the combined switch certificate and the key but rather just the key.
    I had read some other topics on this issue in another forum that appear to have not been the correct instructions.  I thought they would be similar because it was a similar product but that was not the case.  Once I uploaded the Public Cert and the Private Key as well as the DH files and then enabled HTTPS, everything was working as expected.
ProSupport for Business
