inxs4
Nov 22, 2022Aspirant
GS308T VLAN across Multiple switches
Hi, I'm having problems with VLANs. I have GS308Ts, We use VLANs 1, 2, 90, and 100. VLAN 1 works fine. But the other 3 only work on one switch, they don't look at devices across all 3 switches. h...
schumaku
Nov 22, 2022Guru - Experienced User
With all due respect, based on the table provided, VLAN 2, 90 and 100 cant even work on one switch resp. the ports 1...8, as all seem to be configured partially as untagged on these ports.
several configuration parts in place on your previous Cisco environment have not been migrated apparently.
Start with a table defining each switch port VLAN association, read which VLAN you want a connected device associated to.
tTen define each of these ports for an access port for the relevant VLAN.
- inxs4Nov 28, 2022Aspirant
My knowledge of how this works is extremely limited. The guy we had to the work for us said this is how it worked. Not surprising that he was incorrect. My boss tries to get qualified people but doesn't want to pay enough to get experienced people. Now I'm expected to get this to work and I'm beyond lost.
We had our UC560 phone system running on Cisco powered ethernet switches previously without any problems. One of the switches died and wouldn't send power to the phones. So, instead of us replacing 1 cisco switch with the same thing, my boss made the decision to do Netgear instead. Now it's worse than it was because we can only have phones on the same switch as the UC560, instead of anywhere in the office.
- schumakuNov 28, 2022Guru - Experienced User
Convinced that this GS308T (is this a non-PoE model indeed?) can be configured with one or some ports as VLAN trunk ports to connect to the UC and/or the other switch, and have the ports connecting to the desktop phones (are there computers connected to the phones, too?).
Another wild guess: The phones are most likely powered by PoE from the switch (unless there are local power supplies and adapters in the installation). As I said above the GS308T can handle VLANs, but unlikely power the phones.
Is there some configuration documentation around on the UC and the switch config around? Do you have some kind of management access to the UC and the other switch probably?
Is there some drawing of the connections from the UC to the other switches and phones around?
I just realized this drawing was way off. We don't have any computers or printers on switch 1 any longer, they are now wireless. I will fix it because this old one had port 6 going to multiple places, and we ran a very long ethernet cable from switch 2 to that desktop. the connection was very unstable.
