stefankaerst
Oct 07, 2021Aspirant
GS310TP SNMP how to use public community string
Hi!
I have two GS108T and two GS310TP. I successfully use SNMP to monitor the GS108T via snmp public community string without password.
How do I use/configure SNMP public access to the GS310TP? I cannot create any configuration using "public" community strings, because it tells me "Error: Default public and private community strings are not allowed."
on the GS108T I can add/change snmp settings using "public" community strings without restrictions.
so, how do I use SNMP readonly access to the GS310TP using "public" community string. I could not find any hint within the manual.
your help will be much appreciated!
Stefan K.
Using the common default public and private community strings is considered a major security risk, thus depreciated, prohibited, and disabled if set in place. What's the point of not changing to something more effective?
- stefankaerstAspirant
hi schumaku
thanks for your fast reply
schumaku wrote:Using the common default public and private community strings is considered a major security risk, thus depreciated, prohibited, and disabled if set in place.
ok, why?
I agree that SNMP should not be enabled by default, especially no write access. but "public" community string is built-in in many monitoring software.
schumaku wrote:What's the point of not changing to something more effective?
because "public" is well known!?
I added a community string "publik" for read only access, and I had to change my monitoring software for these two switches only. still I cannot see why "publik" is now more effective, more secure than "public" as SNMP v2c is unencrypted anyway.
I bought these type of swiches to manage configuration. I enabled SNMP on purpose. I know what I'm doing here! there is a HP printer which is monitored via SNMP so I can see data about paper and colors in my monitoring software. this is just my home-office network not some 100ge backbone of a company. forcing me to use some community string other than "public" is security through obscurity, IMHO.
SNMP is meant to be simple, hence the S in SNMP.
Regards!
Stefan
You probably don't change your devices default password, too - do you?
So who is able to sniff your wired (or for the sake of it the encrypted wirelss) traffic on your network, and then again on your network management VLAN?
