micliner
Jan 21, 2024Aspirant
GS316EP Traffic Management problem - Switch limits throughput after a time automatically
Hi community, my configuration is built of 2x GS316EP switches connected together using port 1. One switch is placed in the cellar, one switch is placed in a room on the 1st floor. The distance...
schumaku
Jan 21, 2024Guru - Experienced User
Hello Mic,
The only thing coming into my mind is that the link between the two switches (or the link to the device you testing the speed with!) does re-renegotiate and fall back to Fast Ethernet, actively using just to of the four wire pairs.
System -> Management -> Port Status ... Linked Speed
-Kurt
BrianL
Jan 22, 2024NETGEAR Moderator
Hi micliner,
Aside from schumaku' suggestion, you may want to try to isolate the problem by connecting another LAN (wired) device which uses a shorter cable length /or just a different one and see if the problem persists.
Kind regards,
- miclinerJan 22, 2024Aspirant
Good catch ...
Isolating the problem is always agood idea and something I try first.
I have already tried some troubleshooting, but I have not posted what I have tried - sorry for that, maybe I should have posted my troubleshooting steps with the first post.
I tried to keep a long story short otherwise the post would have been a very long letter.
I have two Laptops for "mobile" troubleshooting, that I can use.
One is a Mac the other one is Windows 10 based.
Both have Gigabit Ethernet.
Before the switch on the first floor turned out to be the problem bear, I tried the following:
1. Tried to do performance tests (both Laptops) with 2m cables with the switch located in the cellar
> full throughput
2. Tried the same with the switch on the 1st floor
> limited throughput
I tried different cables to rule out a faulty cable.
3. Reboot the cellar switch and re-test the switch on the first floor (Perf Test Number 2)
> nothing changed
4. Reboot the switch on the first floor and re-test the switch on the first floor (Perf Test Number 2)
> full throughput
I then tried to find a setting on the switch on the 1st floor that could trigger the behavior.
Since I couldn't find anything, I asked in the forum (initial post).thx
mic
