micliner
Jan 21, 2024Aspirant
GS316EP Traffic Management problem - Switch limits throughput after a time automatically
Hi community, my configuration is built of 2x GS316EP switches connected together using port 1. One switch is placed in the cellar, one switch is placed in a room on the 1st floor. The distance...
schumaku
Jan 21, 2024Guru - Experienced User
Hello Mic,
The only thing coming into my mind is that the link between the two switches (or the link to the device you testing the speed with!) does re-renegotiate and fall back to Fast Ethernet, actively using just to of the four wire pairs.
System -> Management -> Port Status ... Linked Speed
-Kurt
micliner
Jan 22, 2024Aspirant
I'll have a look and see what happens if the problem occurs again.
At the moment it is still running at full throughput.
many thx
mic
