micliner
Jan 21, 2024Aspirant
GS316EP Traffic Management problem - Switch limits throughput after a time automatically
Hi community, my configuration is built of 2x GS316EP switches connected together using port 1. One switch is placed in the cellar, one switch is placed in a room on the 1st floor. The distance...
schumaku
Jan 22, 2024Guru - Experienced User
micliner wrote:
I have two Laptops for "mobile" troubleshooting, that I can use.
One is a Mac the other one is Windows 10 based.
Both have Gigabit Ethernet.
Much more interesting would be what the switch port status show on each switch Web UI.
BrianL
Jan 26, 2024NETGEAR Moderator
Hi micliner,
Just update this thread whenever the issue occurs again together with the screenshot and maybe the switch log file.
Kind regards,
- miclinerFeb 11, 2024Aspirant
So far, the problem has not recurred.
Since this is a GS316EP, how do I get a switch log file from it?
many thanks
mic
- schumakuFeb 11, 2024Guru - Experienced User
Nothing the like even exists on these classic Plus switches, which are built on an unmanaged core and a tiny 8051-class micro controller holding the very basic Web UI, and the code for the Netgear Switch Discovery Protocol acessible by the ProSAFE Plus Configuration Utility, pure legacy (!), available as v2.7.8 via older model downloads, like https://www.netgear.com/support/product/jgs524pe#download - requiring Windows systems, requiring a workable installation of Npcap (currrent, legacy API), and the switch configured to allow Switch Management Mode, Web browser and Plus Utility and File Transfer via Plus Utility (TFTP) enabled, too. And yes, this does indeed all work on recent Windows 11 64-bit installations in February 2024. Still no switch log, even for old hardcore engineers 8-)
