micliner
Jan 21, 2024Aspirant
GS316EP Traffic Management problem - Switch limits throughput after a time automatically
Hi community, my configuration is built of 2x GS316EP switches connected together using port 1. One switch is placed in the cellar, one switch is placed in a room on the 1st floor. The distance...
BrianL
Feb 16, 2024NETGEAR Moderator
Hi micliner,
My apologies as this model can't generate logs. Anyway, this is only being experienced on the switch from the first floor and not on the one from the cellar, right? Have you considered switching them to see if the same behavior is being experienced? I don't think there is something wrong with the switches though as the problem only happens every two weeks.
Kind regards,
