insecticide
Aug 23, 2022Tutor
GS316EPP 1.0.3.4 Firmware - can no longer access the switch on the same VLAN
I recently upgraded the GS316EPP to the latest firmware 1.0.3.4 and all of a sudden I couldn't access the switch on the same subnet as the switch is running unless I used the default VLAN (1) admin p...
- Aug 24, 2022
insecticide wrote:
I can this access the switch from any subnet that has rules to get to the admin VLAN/subnet.
Like (almost) all Plus (GSxxxxE[n][n]) switches, there is no managed core, and no management VLAN, never was. Management access is indeed possible from any VLAN, _and_ on untagged connections only, and in case there is IP access configured only for that specific IP (again on any untagged) connection configured to any VLAN. Tagged connections ie. over a trunk don't allow any management access.
insecticide
Aug 23, 2022Tutor
OK, I'll answer my own question, duh 🙂
Yes, this new firmware requires that the switch be in the admin VLAN (1) so changing the switch IP to be in the admin subnet solved this problem. I can this access the switch from any subnet that has rules to get to the admin VLAN/subnet.
- schumakuAug 24, 2022Guru - Experienced User
- Nov 03, 2015Retired_Member
