Alex49
Aug 11, 2023Aspirant
GS324TP - Help configuration
Hello, I would like to configure the S350 Smart Switches (GS324TP) #to connect several ports of an Ethernet Box Below is the functional configuration with only 1 port connected to the Ethernet B...
- Aug 11, 2023
Assuming these Box Ethernet ports are simply Gigabit Ethernet ports, no dedicated routed IP subnets, your Orange Box does not provide performance beyond of 1000 Mb/s anyway: Even if configuring four dedicated VLANs, a switching loop is predictable, either the configured STP or the enabled loop check test will disable one or more ports involved.
In short: Waste of time and effort!
michaelkenward
Aug 11, 2023Guru - Experienced User
Alex49 wrote:
Hello,
I would like to configure the S350 Smart Switches (GS324TP) to connect several ports of an Ethernet Box
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
Your question is about switches. You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Switches - NETGEAR Communities
or
Smart / Plus / Click Switches - NETGEAR Communities
You might like to search there for messages related to your issue.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Alex49
"I will ask the Netgear moderator to move your message." -> Yes please
Thank you for your answer
