MrMystery
Apr 01, 2022Follower
GS324TP not working with my Ubiquity Dream Machine pro via sfp link
Hi all,
I've set both ports to 1G of speed and the link seems to be correct. But when I disconnect my regular UTP cable, I lose my entire connection.
Can anyone tell me if I need to do a change on the UDM pro or on the NETGEAR?
Thank you all for your help
Kind regards
1 Reply
- schumakuGuru - Experienced UserAssuming the unspecified (cable, modules, fiber) config does provide a workable SFP 1000M link - please compare the VLAN config of the working copper ports on both ends with the VLAN config of the SFP ports on boh ends.
