mToddh's avatar
mToddh
GS324tp open a port for unfiltered connection ?
GS324tp                 Is it possible to totally open a port for unfiltered access?
  • Unless there are ACLs or multiple VLANs configured all ports resp. the VLANs are transparent. Not sure what use case you are behind here.
  • schumaku's avatar
    schumaku
    • mToddh's avatar
      mToddh
      We are having problems VOIP phones to the switch,  They are working fine with the old dumb switches.
      • schumaku's avatar
        schumaku
        Disable the AutoVoIP protocol and OUI capabilities - otherwise you might find VoIP device associated to the VoIP VLAN.
ProSupport for Business
