Nettailer
Sep 13, 2022Tutor
GS324TP S350 SFP Port deactivates after 30 seconds to 2 hours
Dear Community, I have a Netgear GS324TP in use as main switch for my home. It is running fine for two years now. Recently I have switched my router to a Ubiqity Dreambox Pro and connected th...
- Sep 14, 2022
If I am using the old router with the GS324 the problem did not occur so far (running for 4 hours now).
I am using a 10Gtek Gigabit SFP Cable (Twinax Direct Attach Copper, Passive). However the issue occurs also on "normal" ports. So I assume it is not the SFP connection that is causing the problem.
It seems that there is a compatibility issue between the Ubiquity Dreambox Pro and the GS324TP because if you are using your old router with the GS324TP, it works just fine.
I suggest you to set up port mirroring on the GS324TP switch. Select the SFP port (that is connected to the Ubiquity Dreambox Pro) as the source port on the GS324TP switch. Then, select another ethernet port as the destination port on the GS324TP switch where a PC (installed with Wireshark) is directly connected. Run Wireshark and observe. It would be best that Wireshark would be able to capture what happens in the source port (wait for the connection to go down as you have stated in your initial post). The moment that the issue happens, stop Wireshark and save the packet capture.
Note: You can get another packet capture but this time, use the ethernet port (that is connected to the Ubiquity Dreambox Pro) as the source port since you mentioned that the issue also occurs using the normal ports.Kindly read pages 319-321 of the GS324TP user manual here on how to set up port mirroring. You may download Wireshark here. As reference, check this link I found online on how to use Wireshark.
For the captured packets to be analyzed, kindly open a chat or online support ticket with NETGEAR Support here and attach the captured packets from Wireshark for it to be analyzed by the NETGEAR Support team as well as state your concern.
DaneA
NETGEAR Community Team
Nettailer
Sep 13, 2022Tutor
Addendum to the inital post:
- the port deactivation also occurs on "normal" (non SFP) ports e.g. port 5
DaneA
Sep 13, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
If you will disconnect your current Ubiqity Dreambox Pro router and connect again your previous router that you were using, does same problem occur?
What is the model of the SFP module you are using?
DaneA
- NettailerSep 13, 2022Tutor
Hi DaneA,
thank you for the warm welcome!
I suspect that the Dream Maschine is doing "strange things". I also factory resetted it but this did not solve the issue.
On the other hand a Netgear ProSafe GS108Tv2 and a Netgear GSS116E did not shut down any port while connected to the Dream Maschine so far.
The Ubiquiti support claims the error occurs on the netgear device and they cannot help with the error message.
I also do not quite understand what the message tries to say with:
Diagnostically disabling interface g25 as rate limit of 15 for 3 consecutive seconds has been exceeded
I understand it is disabling the port but what does rate limit of 15 mean in this context? Is the sender sending to fast?
Best regards
Kai
- Nov 02, 2022Retired_Member
