hacesoft
Jul 25, 2021Tutor
GS724T - access profile from another VLAM / network
Good day, what should I set up to have access to the switch configuration from another VLAN / other network, specifically I want to access the switch via VPN. I have a VPN configured and I can see ...
- Aug 06, 2021
Good day,
after a long search for a solution to why the switch cannot be managed across VLANs or VPNs, I found an error in the IPv4 Network Interface Configuration settings in the Default Gateway field.
I set the right address and divse the world, it's already working :).
hacesoft
Jul 27, 2021Tutor
good day,
i don't use any router, it replaces my PfSense firewall, 2.5.2-RELEASE (amd64) built on Fri Jul 02 15:33:00 EDT 2021 FreeBSD 12.2-STABLE.
Sending photos of firewall settings. In my opinion, I have nowhere blocked communication from VPN to VLAN20. On the firewall there is a policy that is not allowed it does not work and on the switch I think it works the other way around. I don't have a blocked VPN network in the ACL on the switch. I have one port set as a trunk on the switch, and the switch then feeds the individual VLANs to the specific ports. The ACL between individual VLAs is set on the switch. ACL rules do not include VLAN5, which is a network for PfSense firewall and VPN. As I wrote, I think the switch works in a way that is not forbidden in the switch, it works. The routing switch does not perform. It only isolates VLANs.
According to the previous post, I think that a packet from a PC connected via VPN reaches the switch and it no longer responds.
hacesoft
Aug 06, 2021Tutor
Good day,
