becko
Aug 11, 2016Follower
GS724T does it support LACP- I want to enable Port Trunking on Buffalo NAS Backup Drive
I have a Buffalo Terrastaion connected to LAN with 2 discreet Gigabyte Ethernet connections to GS724T. To improve bandwidth I can enable Port Trunking using Dynamic Link Aggregation on Terrastat...
- Aug 12, 2016
Hello becko,
Welcome to community!
There is an option on the switch to enable Static or LACP LAG. You'll have to select this upon creating your LAG membership. Please refer to page 94 and 99 of the User Manual.
Let us know if this helps.
Thanks,
JohnRo
Aug 12, 2016NETGEAR Employee Retired
Hello becko,
Thanks,
