becko's avatar
becko
Follower
Aug 11, 2016
GS724T does it support LACP- I want to enable Port Trunking on Buffalo NAS Backup Drive
I have a Buffalo Terrastaion connected to LAN  with 2 discreet Gigabyte Ethernet connections to GS724T.   To improve bandwidth I can enable Port Trunking using Dynamic Link Aggregation on Terrastat...
  • JohnRo's avatar
    Aug 12, 2016
    Hello becko,
    Welcome to community!
    There is an option on the switch to enable Static or LACP LAG. You'll have to select this upon creating your LAG membership. Please refer to page 94 and 99 of the User Manual.
    Let us know if this helps.
    Thanks,
ProSupport for Business
