Frank1101's avatar
Frank1101
Follower
May 06, 2021
GS724T Wall Mount
Hello,
I am trying to find out whether GS724T can be mounted vertically on the wall.
I am looking for a switch that can be closed in a shallow electrical panel with doors (with some, but minimal air flow).
1. Does it have required mounting openings on the bottom?
2. Can it be placed in such position (ports-up)?
3. Will the minimal air flow be a problem if kept below 55C?
1 Reply
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Frank1101,
    Welcome to our community! :)
    I think there are some community members that have tried to mount it vertically but we do have a click switch that can be mounted vertically.
    It doesn't have mountings at the bottom of the switch, only on the sides.
    Are you planning to wall-mount this?
    Definitely, it will just make the fans run at max depending on how many devices will be connected to the switch.
    John
    NETGEAR Community Team
ProSupport for Business
