jessejames87
Oct 03, 2023Apprentice
Wall Mount rs700
curiosity here when I google rs700 wall mount the following website's description states its compatible with the rs700, then when you read the description on the site it states all wifi 7 devices, however the manual for the mount only lists the new orbi system, anyone know if this works with the rs700 because it's a little misleading to me. https://www.netgear.com/home/wifi/mesh/rbewm/
- So this is an email i just received from netgear.
 Hi Jesse,
 I just received an update that both RBEWM and RBEWMB works for RS700S. Please click the links below for reference.
 https://www.netgear.com/home/wifi/mesh/rbewmb/?_ga=2.150311730.529212470.1696258521-850849134.1696258521#twister-list-block
 https://www.netgear.com/home/wifi/mesh/rbewm/#twister-list-block
 Thank you for choosing NETGEAR.
 Warm Regards,
 April | Technical Support Expert
 So it seems even though the white only lists the orbi 970 series it is compatible with the RS700
- FURRYe38Guru - Experienced UserThanks for posting. Will pass this on. No idea if there going to have such a thing for the RS. đ€ - schumakuGuru - Experienced UserNot sure where the RS700 product relation should come from. The RBEWM Data Sheet does date from 11Sep2003, with no signs of the RS700. Just the title looks to be misleading: - FURRYe38Guru - Experienced UserI believe the user is trying to point out that when searching for wallmounts for the RS700, that that path taken is confusing the way that it's described. Hopefully NG and make an announcement, if and when there maybe something to support the RS as we know there is already for the Orbi 7 systems.
- jessejames87ApprenticeSo the black couldn't be found for me, the white I only found because I googled it. When I try to search the mount on Netgears website it doesn't locate the mounts. now there's no difference from what I can see from the black or white except color however under technical specs the black includes rs700 being compatible as the white only shows the orbi 970 series.
- jessejames87ApprenticeSo this is an email i just received from netgear.
 Hi Jesse,
 Warm Regards,
- cvxdocAspirantSearched for the wall mounts today. Both white and black Product Data Sheets now list Orbi 970 and RS700S.
