grubik
Aug 22, 2025Tutor
GS724TPPv3 (FW v6.1.0.10) PoE MIBs error
Hi, I'm trying to check/enable/disable PoE on switch ports via SNMP. The problem is that I'm using MIBs for firmware version 6.2.1.12 but my switch has firmware version 6.1.0.10 and I do not wish to...
- Sep 02, 2025
Solution was to update Firmware to the latest version and download latest MIBs.
schumaku
Aug 22, 2025Guru - Experienced User
grubik wrote:The problem is that I'm using MIBs for firmware version 6.2.1.12 but my switch has firmware version 6.1.0.10 and I do not wish to update the switch firmware version.
And you seriously ask for some magic solutions please? This is where a part of your problem does start ....
grubik
Aug 22, 2025Tutor
So the solution is just to update firmware?
